It is currently Sun Aug 03, 2025 3:50 pm
PostPosted: Sun Oct 21, 2018 1:15 pm
hi
I see alot of end grafts with black/white/black purfling that is mitre jointed
wondering how you do that?
I use a laminate trimmer to cut the binding slots
here's my end graft and a picture of the mitring I want to do
thanksImageImage
Sent from my SM-G960F using Tapatalk
PostPosted: Sun Oct 21, 2018 1:30 pm
Last Name: Colbert
City: Anacortes
This isn't how I do it but since your end graft is already installed this is likely your best bet. I'm assuming your top and back are on? I cant see them in your photo.
viewtopic.php?f=10101&t=51056
M
These users thanked the author Michaeldc for the post: cablepuller1 (Sun Oct 21, 2018 2:03 pm)
PostPosted: Sun Oct 21, 2018 2:01 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I do it a bit differently from how Robbie shows it in his video. I rout the top or back purfling ledge first like he does, but instead of doing two passes at two depths to cut the binding channel past the end graft, I put a spacer made of the side purfling material on the top or back of the body above the end graft so that the router lifts up by the thickness of the side binding as it passes the end graft and the channel is cut in one pass without having to reset the router depth. I then remove the ramps on each side of the end graft with a chisel and then miter the ends of the end graft purfling with the chisel.
The photo shows the spacer made of the same side purfling used for this guitar. There is a strip of double-sided tape on the guitar and the three purfling pieces are CA glued to the tape. Routing past the spacer leaves ramps on each side of the end graft the same thickness as the side purfling.
The ramps are then removed with chisel and the ends of the end graft purfling are exposed so they can be mitered.
I install the side purfling separately from the binding since that makes it easy to get really good miter joints at the end graft (and at the cutaway if there is one).
These users thanked the author J De Rocher for the post (total 5): frwilliams (Fri Oct 26, 2018 8:13 am) • bftobin (Wed Oct 24, 2018 11:42 am) • Robbie_McD (Tue Oct 23, 2018 8:35 am) • Colin North (Sun Oct 21, 2018 6:23 pm) • cablepuller1 (Sun Oct 21, 2018 2:05 pm)
PostPosted: Sun Oct 21, 2018 2:05 pm
that's a great idea, thanks[THUMBS UP SIGN]
PostPosted: Sun Oct 21, 2018 2:29 pm
First name: Jay
City: Bothell
State: Washington
If you decide to try the spacer method here are a couple tips.
If your router setup is such that there is significant downward pressure of the router, it might be enough to dislodge the spacer from the tape if you try to route up and over the spacer. As Robbie would say, "That happened to a friend of mine once". I use one of those tower setups and mine isn't counterbalanced so the full weight of the router rides on the guitar body. Having three purfling strips as in the photo, instead of just one or two, helps keep the spacer in place. Also the ends of the purfling strips are ramped to make the transition easier for the router. The other precaution I take is to not rout up to the the spacer and then up and over it. Instead I start the cut with the router positioned in the middle of the spacer and move the router off the spacer onto the body in one direction an inch or two and then come back and route from the middle of the spacer off onto the body in the opposite direction. The spacer stays put that way.
When putting a spacer on the top of the body, be careful not to get CA glue into the end grain of the top or it will be permanently discolored.
This approach also works of if you want to have mitered purfling joints around a backstrip. You put the spacers on the side of the guitar over the end graft and the router bearing rides up over the spacer in that case.
These users thanked the author J De Rocher for the post (total 2): frwilliams (Fri Oct 26, 2018 8:15 am) • cablepuller1 (Sun Oct 21, 2018 2:53 pm)
PostPosted: Sun Oct 21, 2018 2:47 pm
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
I do it like Jay but with no spacer. Just route right up to but not touching the tail purfs, only a very small bit left to remove with chisel with this approach. Either way will get the job done though.
These users thanked the author Ken Lewis for the post: cablepuller1 (Sun Oct 21, 2018 2:51 pm)
PostPosted: Sun Oct 21, 2018 7:54 pm
First name: Aaron
I route the ledge first, then install the end graft and purfling proud, trim down the end graft and mitre the purflings. I’ve never seen it done other ways, but then again, I live on a rock. :D
Of course, I’m guessing jigs like this exist to install the end graft after routing.
http://www.luthiertool.com/edge_vise.html
These users thanked the author Aaron O for the post: cablepuller1 (Mon Oct 22, 2018 12:33 am)
PostPosted: Sun Oct 21, 2018 11:18 pm
I do it like J DeR.
These users thanked the author Terence Kennedy for the post: cablepuller1 (Mon Oct 22, 2018 12:33 am)
PostPosted: Mon Oct 22, 2018 3:26 am
First name: Miguel
Last Name: Bernardo
Country: portugal
I still haven’t found my ideal way of doing this. Gluing the purflings separately does allow for a much easier mitter cutting but then bending the thin lines is tougher (at least for me). Gluing the purfs to the binding first works exactly the opposite, making cutting nice mitters harder. What I’m thinking of doing next time is to glue the purfling lamination 1st, then gluing it to the binding stock, but leaving an inch or two at the end unglued, so that it’s free and I can mitter it easier. Does it makes sense?
OTOH is that a single purf line you have in the end graft? I think mitters work better for wider purfs. I do like your end graft design.
These users thanked the author mqbernardo for the post: cablepuller1 (Mon Oct 22, 2018 12:56 pm)
PostPosted: Mon Oct 22, 2018 9:48 am
The place where the line is visible is in the white or light part of the miter. You may get it perfect at glue up but the line sometimes becomes visible after scraping flush.
Has anyone used any kind of white filler to deal with an unexpected gap? I just got some of the white tinting powder for the GluBoost product. I am going to mess around with that on some scrap.
These users thanked the author Terence Kennedy for the post: cablepuller1 (Mon Oct 22, 2018 12:57 pm)
PostPosted: Mon Oct 22, 2018 10:04 am
Last Name: Colbert
City: Anacortes
Yup... This is how I did it before I bought the above mentioned edge vise from luthiertool.com.
Now I do this which I do after the bindings are installed.
These users thanked the author Michaeldc for the post (total 2): Bryan Bear (Tue Oct 23, 2018 9:28 am) • cablepuller1 (Mon Oct 22, 2018 12:58 pm)
PostPosted: Mon Oct 22, 2018 10:33 am
First name: Jay
City: Bothell
State: Washington
To bend the side purflings, I reduce their height before bending. The purflings I buy are typically about 0.110" tall. At that height, they tended to crimp and/or twist when I tried bending them for tight bends. My binding channels are usually 0.070" deep so I run the purfling through my band saw to reduce the height to right about 0.085" which leaves them a bit proud of the sides after they are installed. I sandwich two purfling pieces between to binding pieces, tape them together tightly, and bend them together. The side purfling bends smoothly this way even through the tight bends. I run the purfling through the band saw on a zero clearance support that has the slot positioned 0.085" plus or minus a hair away from the fence. The cut edge is rough but running a razor blade along the length as a scraper smooths it out and that edge goes to the inside of the binding channel.
PostPosted: Mon Oct 22, 2018 12:40 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Similar to some of the advice offered thus far, our approach is to close the body and block sand to smooth and fair, install the end graft with purfing, then rout the binding and purfling channels using purfling-thickness spacer at the tail graft and any other location with miter work. Rather than try to use purfling scraps directly, our spacers are scrap maple 1.5" x 6" strips sanded to correct thickness...easy to make them up when each order of purfling stock arrives (0.040" BWB is never exactly 0.040") or after bending. The mirror polish on the back of a chisel makes trimming the four miters straightforward (see Cumpiano for that technique).
We gang-bend side purflings in the Fox bender when using plastic binding and install before the binding. For wood bindings, the purfs get attached prior to bending, so are mitered and fitted with binding attached. Bending can change the dimension of a purfling (heat and moisture, compression and tension), so we check that before committing to a spacer thickness. We consider spacers to be sacrificial, so set them to be partially trimmed away during the end graft or Florentine area rout...this further stabilizes the routing process and avoids any issues with donut design or bit clearances on top-guided binding channel jigs such as the Williams or Ribbeke-style machines.
- Beth Brower
These users thanked the author Woodie G for the post: cablepuller1 (Mon Oct 22, 2018 1:00 pm)
PostPosted: Tue Oct 23, 2018 7:25 am
Last Name: Tracz
This end graft is fantastic! I was going to respond with I do it the same as you guys do but then I saw this one and now you have me thinking about trying something new! The execution is very well done. Super tight and the proportions spot on.
Thank you for sharing!!!
_Mike
_Mike Tracz
MCT Guitars
https://www.instagram.com/mustcreatethings/
https://www.youtube.com/mustcreatethings
These users thanked the author mtracz for the post: Michaeldc (Tue Oct 23, 2018 7:32 am)
PostPosted: Tue Oct 23, 2018 7:38 am
First name: Willard
Last Name: Guthrie
City: Cumberland
_Mike
I would love to see what the side purfling mitered into the end graft purfling would look like...that design is already quite attractive...having those white purfling lines flow around the graft would be an interesting effect.
- Beth Brower
These users thanked the author Woodie G for the post: Michaeldc (Tue Oct 23, 2018 9:13 am)
PostPosted: Wed Oct 24, 2018 10:05 am
Last Name: Colbert
City: Anacortes
This will be obvious to many and hopefully helpful to some. It takes about 20 minutes once you've done a couple.
These users thanked the author Michaeldc for the post (total 4): frwilliams (Fri Oct 26, 2018 8:19 am) • DannyV (Thu Oct 25, 2018 8:46 am) • Bryan Bear (Wed Oct 24, 2018 11:40 am) • cablepuller1 (Wed Oct 24, 2018 10:20 am)
PostPosted: Wed Oct 24, 2018 10:47 am
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
Right on!!
Tony Thatcher
Bozeman, Montana
PostPosted: Wed Oct 24, 2018 12:55 pm
First name: Brad
Last Name: Combs
This time is a first for me doing the purfling first then the binding, but it made the miters a lot easier for me. I was able to get it all lined up and ready, then tack on with CA. Thanks for the help from various threads on this topic. I liked the results.
The spacer is HDPE that is 0.070 thick and the same height as the binding.
Brad
These users thanked the author bcombs510 for the post: cablepuller1 (Thu Dec 20, 2018 1:25 am)
PostPosted: Wed Oct 24, 2018 1:11 pm
Last Name: Colbert
City: Anacortes
Brad
Looks nice and clean!
These users thanked the author Michaeldc for the post: bcombs510 (Wed Oct 24, 2018 1:18 pm)
PostPosted: Fri Dec 14, 2018 1:29 pm
Very nice both Brad and Michael!
I did a similar one recently and was surprised that it actually was easier to do it Micheal's way than the way I'd been doing it, and it looks fancier too!
PostPosted: Fri Dec 14, 2018 1:46 pm
Btw, Brad, how did you bend your purflings?
PostPosted: Fri Dec 14, 2018 3:03 pm
First name: Larry
Last Name: Hawes
Here's a short tut from 5 years ago. Hope it helps...
viewtopic.php?f=10117&t=40548
Thank You and Best To All
PostPosted: Fri Dec 14, 2018 6:05 pm
First name: Brad
Last Name: Combs
I actually didn’t pre bend them. Also something new for me recently is I’m using the long bwb strips from Gurian that go the entire perimeter of the guitar in one strip. So for the purfling on the bottom edge of the bindings (front and back) and the purfling around the soundboard there are no joints (for me means no gaps :D ). The only purfling joint I had to worry about is the one on the back since nothing covers it. Those are coming out nicely as well. And the miters, for me, we’re no stress using the CA.
Hope that helps.
